Since the part originally was already modeled in a really goofy origin, I am having issue with trying to re-origin the flat face to be a front view.
I have attached the part file for everyone to view.
Thanks in advance.
Thanks in advance.
Somehow I can't select to front face of the part - seems like it's not flat as Mather mentioned
Anyway, what I'd do is to leave the "123" part alone (in case I need it for ref). Create a new part and insert that "123" into the new part and use the mate to constrain it to whatever position I want
It all depends what his intent is. If his intent is to use it once and never use it again, I suggest modeling his new part in the already existing one and then supressing the body. This way he could have a configuration with the rounded part and the original body and keep all his mates, and he could have the configuration explecitely used for drawing intentions.
If he wants to make a clean part that he will use on the long run, your method is the ideal solution.
Hello Jeff,
I believe you could use the move command to get the result you want but the reason you are having difficulties is because the part isn't flattened.
Here is what I mean:
Here is what I could do with the existing part to relocate it close to the origin but it's still lofted.
