I have an dll library Gma.QrCodeNet.Encoding.dll to encode QRCODE in drawings. but macro can't find the function QREncode to do that.
text of macro is below:
Dim swFeat As SldWorks.Feature
Dim swSketchPicture As SldWorks.SketchPicture
Dim boolstatus As Boolean
Dim width As Double
Dim height As Double
Dim angle As Double
'Dim oc As OcvitaBarcode1
'Imports OcvitaBarcode.barcode
Option Explicit
Private Enum TErrorCorretion
QualityLow
QualityMedium
QualityStandard
QualityHigh
End Enum
Private Declare PtrSafe Sub GenerateBMP Lib "D:\Gma.QrCodeNet.Encoding.dll" Alias "QrEncoder" (ByVal FileName As String)
'Set oc = OcvitaBarcode1
'oc.barcode = TextBox1
GenerateBMP StrPtr("Hello world!")
' Set swModel = swApp.NewDocument("C:\ProgramData\SolidWorks\SOLIDWORKS 2017\templates\gost-part.prtdot", 0, 0, 0)
Set swModel = swApp.ActiveDoc
' swModel.SketchManager.InsertSketch True
Set swSketchPicture = swModel.SketchManager.InsertSketchPicture("c:\temp\IMG_4359.jpg")
boolstatus = swModel.Extension.SelectByID2("Sketch Picture1", "SKETCHBITMAP", 0, 0, 0, False, 0, Nothing, 0)
Set swFeat = swSelMgr.GetSelectedObject6(1, -1)
Debug.Print "Feature name = " & swFeat.Name
boolstatus = swSketchPicture.Flip(False)
Debug.Print " Sketch picture flipped? " & swSketchPicture.Flipped
swSketchPicture.GetSize width, height
Debug.Print " Width: " & width * 1000 & " mm"
Debug.Print " Height: " & height * 1000 & " mm"
angle = swSketchPicture.angle
'1 radian = 180º/p = 57.295779513º or approximately 57.3º
Debug.Print " Angle: " & angle * 57.3 & " degrees"
