I have a PVZ File I need to extract MUCH info from.
I understand it is a "Creo" File. I assume it is their version of an eDrawings File.
Is it at all usuable inside solidworks..? Even as a dumb solid would be fine.
I'm hoping someone here has some experience to assist me.
FYI, No reverse engineering here... The file was supplied for a truck we are fitting a large frame to.
I need the Chassis hole patterns and associated bracketry to work out our mounting brackets, etc..
If it's the equivalent of an Edrawings file you won't get any solids. Display data only.
