Hello there all, I have just today installed Visualize 2018 and have been having a play and come across an issue (I'm having). I've tried to resolve with a bit of digging but now I'm a bit stuck and no closer to an answer. I will try and explain:
When I import a new model (previous Visualize projects seem to be fine) the "re-import all models and parts" is greyed out. When I click on the model in Visualize and go to "Original Source" it says "there is no information available". This has happened on both of the new models I have tried to import?
Regards
Lee
Hi Lee,
Those settings are only enabled if you have chosen 'Monitor File' from the Import settings at the time of first import. This setting must be checked upon first import. Note "Appearance" part grouping mode does not support Monitor File, since that mode merges all parts sharing the same appearance into one simple part in Visualize.
