printout2
Question asked by Hank Costner on Oct 31, 2017
Latest reply on Oct 31, 2017 by Hank Costner
Hello all,
I'm new to using SW API. The code I wrote is meant to take sheets from a drawing and save them as PDF's. I want to control what the filenames are from the program. That's what I'm trying to using the variable fileNames for.
I have a drawing open with many sheets when I run the API from the edit window.
My default printer is set to Microsoft Print to PDF.
The code compiles, and I'm not sure if the PDF's are being made and saved somewhere random, or if I'm missing something in my code.
Any ideas?
Here's my code:
Dim swApp As Object
Dim swModel As Object
Set swModel = swApp.ActiveDoc
    If (swModel Is Nothing) Then
        MsgBox "No active drawing found in SolidWorks." & Chr(13) & Chr(13) _
            & "Please load/activate a SolidWorks drawing ", vbExclamation
        End
    If (swModel.GetType <> swDocDRAWING) Then
        MsgBox "Current document is not a drawing." & Chr(13) & Chr(13) _
        End
Dim numberOfSheets As Integer
Dim SalesPageToPrint(0) As Integer 'Page Array
Dim FabPagesToPrint(1) As Integer 'Page Array
Dim n As Integer 'file name placeholder
Dim fileNames 'names for files
Dim pageIncrement As Integer 'used to step through Page Array
Dim i As Integer 'iterator
numberOfSheets = swModel.GetSheetCount
SalesPageToPrint(0) = 1
FabPagesToPrint(0) = 2
FabPagesToPrint(1) = 3
i = 0
n = 0
fileNames = Array("125112-Production.pdf", "125112 - Sales", _
"125117 - Production", "125117 - Sales")
Do While i < 3
swModel.Extension.PrintOut2 SalesPageToPrint, 1, True, "", fileNames(n)
n = n + 1
swModel.Extension.PrintOut2 FabPagesToPrint, 1, True, "", fileNames(n)
SalesPageToPrint(0) = SalesPageToPrint(0) + 3
FabPagesToPrint(0) = FabPagesToPrint(0) + 3
FabPagesToPrint(1) = FabPagesToPrint(1) + 3
n = n + 1
i = i + 3
Loop
