I'm having trouble hard-coding an array. It's called "filenames", and it's defined about half-way through. I've tried to assign values a few different ways, and right now, I'm trying to do it dynamically.
The error the compiler is giving me is Runtime error '13': Type Mismatch.
I defined filenames dynamically as a string (I think).
I'm not familiar with the SW coding environment. I normally use C++ and MatLab.
I'm using SW 2016 SP5, and when I make a new macro, it opens a Microsoft Visual Basic for Applications Window. I thought that meant I'm using VBA, but some VBA syntax hasn't worked, like the "End While" statement. So I'm not sure if this is API or VBA.
I included my code below. I have a drawing with a lot of sheets open when I run the code.
Dim swApp As Object
Dim swModel As Object
Set swModel = swApp.ActiveDoc
If (swModel Is Nothing) Then
MsgBox "No active drawing found in SolidWorks." & Chr(13) & Chr(13) _
& "Please load/activate a SolidWorks drawing ", vbExclamation
End
If (swModel.GetType <> swDocDRAWING) Then
MsgBox "Current document is not a drawing." & Chr(13) & Chr(13) _
End
Dim numberOfSheets As Integer
Dim SalesPageToPrint(0) As Integer 'Page Array
Dim FabPagesToPrint(1) As Integer 'Page Array
Dim n As Integer 'file name placeholder
Dim fileNames() As String 'names for files
Dim pageIncrement As Integer 'used to step through Page Array
Dim i As Integer 'iterator
numberOfSheets = swModel.GetSheetCount
SalesPageToPrint(0) = 1
FabPagesToPrint(0) = 2
FabPagesToPrint(1) = 3
i = 0
n = 0
fileNames = Array("125112 - Production", "125112 - Sales", _
"125117 - Production", "125117 - Sales")
Do While i < 3
swModel.Extension.PrintOut2 SalesPageToPrint, 1, True, "", fileNames(n)
n = n + 1
swModel.Extension.PrintOut2 FabPagesToPrint, 1, True, "", fileNames(n)
SalesPageToPrint(0) = SalesPageToPrint(0) + 3
FabPagesToPrint(0) = FabPagesToPrint(0) + 3
FabPagesToPrint(1) = FabPagesToPrint(1) + 3
n = n + 1
i = i + 3
Loop
