Hello -
I am currently trying out Inspection 2017 to see if it can cut down on our labor hours spent making new FPAI/FAIR documents. The only thing left to try and automate is our "Zone" column which is used to say where the balloon/feature is to help our inspection team quicken their processes.
Although I can set up zones in Sheet Properties > Zone Parameters, I am unable to figure out how to pull that information about what grid section each balloon is in.
The exporter for Inspection 2017 uses expressions like:
iex:INSPECTIONXPERT/SAMPLE_SHEET/CAD/ATTRIBUTES/ATTRIBUTE[@selected='True']/@prefix
iex:INSPECTIONXPERT/SAMPLE_SHEET/CAD/ATTRIBUTES/ATTRIBUTE[@selected='True']/@value
So I tried doing:
iex:INSPECTIONXPERT/SAMPLE_SHEET/CAD/ATTRIBUTES/ATTRIBUTE[@selected='True']/@zone
It may not come as a surprise that this did not work. But there *has* to be a way to pull that information from a drawing using "code", no? Why would that feature even be in SW if you are not able to pull that information?
Thank you for your time,
Ian
