I am currently working on Flow simulation solidworks. From several videos I find the PCB component editing feature which enables us to change layer properties settings.
However, in my current 2016 solidworks I can not find the printed circuit boards option in engieering database.
So I am wondering this issue is related to lisense of electronics cooling module or more related to some setting in solidworks?
Thanks.
Hi Xin,
If your Flow Simulation license has the Electronics Cooling Module (ECM) attached to it then you should see the PCB options immediately. It sounds like your license doesn't have this though. You probably want to give your VAR a call to confirm this though.
