Deepak Gupta
Macro: Save Last Sheet As PDF
Discussion created by Deepak Gupta on Oct 25, 2017
Latest reply on Feb 7, 2019 by Rubén Rodolfo Balderrama
Macro to save last sheet in the active drawing as PDF. Please backup your data before using the macro.
The macro is made in SW2017 version but should work on lower version also. In case you're running a different version then update/correct the macro reference as suggested here (don't worry on the fact that video is for fixing missing library error but check the process to update your macro library): Fix-Update SOLIDWORKS Macro References
