Macro to insert BOM into sheet and link to configuration in that sheet
Question asked by Grant Kirkland on Oct 24, 2017
Latest reply on Oct 25, 2017 by Omkar Deshpande
I have a macro which will insert a BOM into a sheet, and another (thanks Deepak) which renames the sheet to match the configuration name.
I would like to combine these macros.
Goals:
Rename sheet to configuration name
Insert BOM (top level only)
Rename BOM to <Configuration name> BOM
Link BOM to the first (or any?) drawing view on each sheet (or not linked at all? I'm not sure...)
I don't want the drawing views linked to a BOM, I just want the BOM on the sheet because all views on a sheet will always be linked to the BOM inserted into that sheet.
I hope some of that makes sense.
This is what I have so far:
Dim swSheet As SldWorks.Sheet
Dim swModelview2 As Configuration
Dim ConfigName As String
Dim vSheets As Variant
Dim swView As SldWorks.View
Dim i As Integer
Set swModel = swApp.ActiveDoc
vSheets = swModel.GetSheetNames
For i = 1 To swModel.GetSheetCount
swModel.ActivateSheet vSheets(i - 1)
Set swSheet = swModel.GetCurrentSheet
Count = swModel.GetModelViewCount
Set swView = swModel.GetFirstView
Do While Not swView Is Nothing
ConfigName = swView.ReferencedConfiguration
Set swView = swView.GetNextView
Loop
swSheet.SetName ConfigName
    ' Select Drawing View1
    swModel.ClearSelection2 True
    boolstatus = swModel.Extension.SelectByID2("Drawing View1", "DRAWINGVIEW", 0#, 0#, 0#, True, 0, Nothing, swSelectOptionDefault): Debug.Assert boolstatus
    Set swView = swModel.SelectionManager.GetSelectedObject6(1, -1)
    'Set swView = swModel.GetFirstView
    ' Get selected drawing view
    AnchorType = swBOMConfigurationAnchorType_e.swBOMConfigurationAnchor_TopLeft
    BomType = swBomType_e.swBomType_TopLevelOnly
    Configuration = ""
    TableTemplate = "C:\Vault\Templates\Standard Bom - PDM.sldbomtbt"
    ' Insert BOM table
    Set swBomAnn = swView.InsertBomTable2(False, 0.45, 0.28, AnchorType, swBomType_e.swBomType_TopLevelOnly, Configuration, TableTemplate)
Next i
' Rebuild
swModel.EditRebuild3
' Zoom To Fit
swModel.ViewZoomtofit2
' Save
swModel.Save2 False
