Log in to create and rate content, and to follow, bookmark, and share content with other members.
When I use the flatten option, I get a 1 inch long section that should be 68 inches long. I followed two different Youtube videos to the letter but cannot get it to work. What am I doing wrong?
Question asked by Roger Byrum on Oct 23, 2017 Latest reply on Oct 23, 2017 by Todd Blacksher
Attach your part and you will make it easier for us to diagnose the problem and offer help. Go to the link for "Use advanced editor" in the upper right corner of the reply and then in the lower right corner you'll see a paperclip icon next to the word "Attach".
Thanks Todd, you pointed me to the right place and I got it to work. But... Override default parameters was unchecked in my environment. I "checked" it to make it work?!
them pesky k factors are something else when flattening a round bend. I found that if they are not set right then all kind of strange things can happen and then the shop has heck getting the right bent dimensions. try doing something that is 12ft dia and have a goof or two...that is a lot of scrap.
For any large radius bend, i.e., where the bend radius is 5x the material thickness, the neutral axis is right in the middle of the material, therefore a K-factor of .5 is correct.
I unchecked the "Overrides" in the sheet metal feature, and it flattens to the full length now (68.579in)
