SOLID WORKS does not run. It has been running serveral weeks ago.
I have installed both Versions, 2017 and 2018, but without any success.
How can I manage this Problem?
Well, I live in Austria and I use SOLID WORKS in german language.
It says that SOLID WORKS does not funktion any longer.
The program does not run properly due to a problem. The program will now shut down
and I will be informed if a solution is available.
The original message in German:
SOLID WORKS 2017 funktioniert nicht mehr.
Das Programm wird aufgrund eines Problems nicht richtig ausgeführt.
Das Programm wird geschlossen und Sie werden benachrichtigt, wenn eine Lösung verfügbar ist.
Try to reinstall graphic card driver.
http://www.solidworks.com/sw/support/videocardtesting.html
In Win 10, there are a lot of problems with win 10 updates.
Well. What kind of error message it gives? Or does it give one at all?
