Can contact sets be used for a drop test?
Question asked by Keith Olson on Oct 20, 2017
Latest reply on Nov 14, 2017 by Greg Hoepfner
I have a simple assembly of 2 overlapping blocks, attached image. I am dropping them onto the edge of on of the blocks, bottom-most edge in image.
If I use Global Contact the drop test will run. If I use Component Contact the drop test will run.
If I use Contact Set the drop test will not run.  I get an error "Incompatible bonding is not supported by Drop Test. Please define compatible bonding."
There is not an option to make a contact set have a compatible mesh, does this mean that Contact Sets cannot be used for a drop test?
