8 Replies Latest reply on Oct 23, 2017 6:05 AM by Mr Omkar Deshpande
    Suggestion for how to Automate Macro
    Stefanie Davis
      I have assembled code that...
      1. Generates Windows username.
      2. Sets the UserName as a property.
      3. Rebuilds the document (allowing any linked values to automatically update).
      Dim swApp As Object
      Dim Part As Object
      Dim boolstatus As Boolean
      Dim swModelDoc As SldWorks.modelDoc2
      Set swModelDoc = swApp.ActiveDoc
      'https://forum.solidworks.com/thread/90475#472929
      'get username from windows login
          Dim UserName As String
          UserName = Environ("USERNAME")
          '(i used this to verify code was working)MsgBox UserName
      Dim cpm As SldWorks.CustomPropertyManager
      Set cpm = swModelDoc.Extension.CustomPropertyManager("")
      'delete old "UserName"
          cpm.Delete "UserName"
      'regenerate new value for "UserName"
          cpm.Add2 "UserName", swCustomInfoText, UserName
      'http://www.eng-tips.com/viewthread.cfm?qid=248582
      'rebulid drawing, so above-mentioned property will update
          Dim modelDoc2 As modelDoc2
          Set modelDoc2 = swApp.ActiveDoc
          modelDoc2.EditRebuild3
      All of the above is working correctly.
      What I now want to do is have this code launch every time a drawing is printed (as i want the username to appear on the drawing).
      What are my options? I was thinking that maybe when the "print" command is activated it automatically happen?  or maybe when a drawing is opened it happens?  Not sure how difficult any of this is.  Thanks!
