I go to the design library and download the weldment profiles, it won't like me download them in the existing weldment profile folder so I created my own folder, I added that folder to the file location for weldment profiles but nothing else shows up except the default sizes. just wondering what I'm missing or not doing correctly.
Hi Tim,
The folder you point to under 'Tools', 'Options', 'System Options', 'File Locations', "Weldment Profiles" needs to have a very particular relative folder structure beneath it. It needs to have this:
...like...
Further, you cannot have duplicates of standards so if you have two folders listed like this:
...that both have "ansi inch" folders beneath them then only one is going to get recognized. You may want to make sure only one path is listed under 'File Locations' and that it points to the folder containing the folder that is the standard you downloaded. Or, otherwise, copy your standard into the default weldment profile directory after extracting it (sometimes it just can't extract to that location but will copy there just fine). If you want to try to just doing the top-to-bottom setup again you the process is detailed here (GoEngineer - Weldment Profile Download and Setup)
