MSMatt Smith17/10/2017
I am trying to use the autotrace feature using a fairly simple image (attached). When I get into the Sketch Picture menu I can select transparency from file and remove the "black rectangle" that shows up by default and see the image properly, however when I select Next to get into the trace settings the image again becomes completely black. Is there a step I am missing?
Thank you!
