Thicken side 2 is working but Thicken side 1 and Thicken Both Side is producing error result. What is the reason for that?
Definitely weird, mid will work up to around .75mm, unidirectional will work either way up to around .95mm
I'm sure there is a valid reason, I just don't have an answer for you right now . . .
..apply tangent conditions between your sketch (sketch10, 3dsketch3) and surfaces (surface loft1, mirror4)
Did you read all the replies
1) When 2 surfaces don't have a good connection, it'd create a gap when thickening
2) when you apply mirror feature to surface, make sure it's normal to the plane
3) when you use loft feature to connect surfaces, make sure use end constrain to create a good connection
Then you won't get error thickening either side
..ok,.. then you need to "help" solidworks out with this,.. that is, help it understand you need to "maintain and extend" those corners... when working with surfaces,.. always think like a "seamstress" always account for extra "fabric" material for the boundaries be sewn together.
..there are a couple was to do this but you want to offset just the surfaces...
so, you would create boundaries or patches at the 4 corners (images attached)
..and sew or knit them... then, thicken.
