I am trying to create an assembly template to quickly generate an assembly from survey data. The assembly contains a weldment, end plates and stiffening brackets. I would like to be able to vary the position of beams and the dimensions of the plates.
I have set the assembly as a template and have included the parts required. The assembly and parts get assigned their own serial number and. It all looks right when launching the template, but the assembly references the template parts as opposed to the ones that were created along with the assembly. Is it possible to have the references in the assembly update when launching the template? Does any one know of a work around?
Kind regards,
Stavros
Have you looked at DriveWorks Xpress? I've been experimenting with it to do something similar to what you're talking about and it's working well so far.
