I am working on an impeller and I am trying to extract the core from the model but I cannot get the tooling split to save my life. It jsut keeps saying that it can't knit the surfaces.
I tried using the STEP in and out method but that didn't work either.
I realize that I am using a machined model but the internal is the same as the as cast (which has an odd parting line, which I might have screwed up). The draft is correct in the model and should not be changed.
Any ideas?
For starters, don't use parting line surfaces function. Reorder your tree. Import, Parting Line, Shut off Surfaces, create a parting line plane, tooling split.
Parting Line
Shut Off Surfaces (Notice Knit is Checked)
Parting Line Surface
Tooling Split
I am using 2017 so you can't have the file (not that I would send it anyways)
