Hi
I have been using Composer (2015 SP0) for a few years without trouble and recently went to FILE>DEFAULT DOCUMENT PROPERTIES>VIEWPORTS to set a custom camera angle to be consistent with other drawings and the CUSTOM CAMERA VIEW fields are missing.
I recently transferred the licence from a PC running Windows 7 to one running Windows 10 Home. I tried repairing the install to no avail. Could Windows 10 be my problem?
On another issue, Composer is running s l o w. Could this also be related to the issue above?
PC is DELL XPS 15 9550 (16GB RAM 2.6GHz processor).
Thanks very much.
First to your Hardware: not the processor, not the ram, but the grafikcard would be interesting! This is the main factor for performance. Which one do you use?
May be there are some problems with your preferences in the registry.
Also it may be possible, that you Need Windows 10 professional.
