I am having a lot of difficulty using the "Set as Neutral Properties" and "Restore Neutral Properties" commands. I am working on a storyboard with a very large assembly, and I keep having to add components by importing them as .step files. Quite often these components need to be translated and rotated into their correct position. Once in the correct position, I want to set that position as the neutral position.
My process is that I select the part I just imported in assembly selection mode and click "Set Neutral Properties." Then I switch to part selection mode and click "Set Neutral Properties". Then I click "Restore Neutral Position" (or ctrl+R) and the parts go back to where they were when I imported them. I press ctrl+Z to get them back to where I wanted them, then repeat selecting them in different ways and clicking "Set Neutral Properties" several times, sometimes selecting the entire ROOT assembly and clicking "Set Neutral Properties." Sometimes this works, and sometimes when I press CTRL+R they parts STILL go back to the wrong place!
Can somebody please explain the black magic I need to use to make "Set Neutral Properties" work correctly?
Thanks for your help
Hi Blair,
your way to set neutral properties seems to be correct, but be sure, that there is no other property selected in the Properties menu.
If you want to set a paticular property like Color, you will be able only to set this property by using "Set as Neutral Properties"
In this case select the actor/part/assembly, second select the property and than use "Set as Neutral Properties"
But there is no Property to set the Position. In this case you have to deselect all properties and than use "Set as Neutral Properties". This will set ALL PROPERTIES of the actor inclusive the Position.
First image shows the selected Color, second Image without any selected properties!
