How can I get the correct orientation for sketches in some macro commands on some PC's running SW2017?
Question asked by Adam Kaplan on Oct 13, 2017
Latest reply on Oct 16, 2017 by Jacob Corder
Hello all,
We have an SWB macro, has always worked well for many years. In SW2017, we started having an issue on a particular computer with the orientation of the sketches.
The macro produces a hub, lofted using 9 sketches. When the macro executes properly, we get a hub:
In SW2017, on this particular computer, the orientation the sketch changes throughout the macro and causes the loft to fail:
The macro for the hub only is provided below for your review:
' blade surface macro built by HydroComp PropCad 16.04.0029
' 2016/12/19-13:40
' for SolidWorks 2010+
' all data in meters
Const swDisplayTemporaryAxes = 7
Dim swApp as Object
Dim Part as Object
Dim boolstatus as Boolean
Dim CreatedPlane(0 To 8) as String
    Call Hub()
End sub
' hub envelope macro built by HydroComp PropCad 16.04.0029
' 2016/12/19-13:40
Sub Hub()
Set Part = swApp.NewPart
Dim RefPlane As String
Dim blnDispGrid As Boolean
Dim dblGridSpacing As Double
Dim blnSnap As Boolean
Dim blnDotStyle As Boolean
Dim dblMajor As Double
Dim dblMinor As Double
Dim blnAlign2Edge As Boolean
Dim blnAngleSnap As Boolean
Dim dblAngleUnit As Double
Dim blnMinorAuto As Boolean
blnAlign2Edge = False
RefPlane = "Right Plane"
CreatedPlane(0) =  "Plane1"
CreatedPlane(1) =  "Plane2"
CreatedPlane(2) =  "Plane3"
CreatedPlane(3) =  "Plane4"
CreatedPlane(4) =  "Plane5"
CreatedPlane(5) =  "Plane6"
CreatedPlane(6) =  "Plane7"
CreatedPlane(7) =  "Plane8"
CreatedPlane(8) =  "Plane9"
Part.GridOptions False, 0, False, False, 0, 0, False, False, 0, False
Part.SelectByID RefPlane, "PLANE", 0, 0, 0
Part.CreatePlaneAtOffset 0.0762, 1
Part.CreatePlaneAtOffset 0.05953125, 1
Part.CreatePlaneAtOffset 0.0428625, 1
Part.CreatePlaneAtOffset 0.02619375, 1
Part.CreatePlaneAtOffset 0.009525, 1
Part.CreatePlaneAtOffset 0.00714375, 0
Part.CreatePlaneAtOffset 0.0238125, 0
Part.CreatePlaneAtOffset 0.04048125, 0
Part.CreatePlaneAtOffset 0.05715, 0
Part.ClearSelection
Part.SelectByID CreatedPlane(0),"PLANE",0, 0, 0
Part.InsertSketch
Part.CreateCircle 0, 0, 0, 0, 0.048006, 0
Part.InsertSketch
Part.SetAddToDB (True)
Part.ClearSelection
Part.SelectByID CreatedPlane(1),"PLANE",0, 0, 0
Part.InsertSketch
Part.CreateCircle 0, 0, 0, 0, 0.04763542, 0
Part.InsertSketch
Part.ClearSelection
Part.SelectByID CreatedPlane(2),"PLANE",0, 0, 0
Part.InsertSketch
Part.CreateCircle 0, 0, 0, 0, 0.04718447, 0
Part.InsertSketch
Part.ClearSelection
Part.SelectByID CreatedPlane(3),"PLANE",0, 0, 0
Part.InsertSketch
Part.CreateCircle 0, 0, 0, 0, 0.04657279, 0
Part.InsertSketch
Part.ClearSelection
Part.SelectByID CreatedPlane(4),"PLANE",0, 0, 0
Part.InsertSketch
Part.CreateCircle 0, 0, 0, 0, 0.04572, 0
Part.InsertSketch
Part.ClearSelection
Part.SelectByID CreatedPlane(5),"PLANE",0, 0, 0
Part.InsertSketch
Part.CreateCircle 0, 0, 0, 0, 0.04457254, 0
Part.InsertSketch
Part.ClearSelection
Part.SelectByID CreatedPlane(6),"PLANE",0, 0, 0
Part.InsertSketch
Part.CreateCircle 0, 0, 0, 0, 0.04318397, 0
Part.InsertSketch
Part.ClearSelection
Part.SelectByID CreatedPlane(7),"PLANE",0, 0, 0
Part.InsertSketch
Part.CreateCircle 0, 0, 0, 0, 0.04163467, 0
Part.InsertSketch
Part.ClearSelection
Part.SelectByID CreatedPlane(8),"PLANE",0, 0, 0
Part.InsertSketch
Part.CreateCircle 0, 0, 0, 0, 0.040005, 0
Part.InsertSketch
Part.ClearSelection
Part.SelectByID CreatedPlane(0), "PLANE", 0, 0, 0
Part.InsertSketch
Part.CreateCircle 0, 0, 0, 0, 0.022225, 0
Part.InsertSketch
Part.ClearSelection
Part.SelectByID CreatedPlane(8), "PLANE", 0, 0, 0
Part.InsertSketch
Part.CreateCircle 0, 0, 0, 0, 0.01805781, 0
Part.InsertSketch
Part.ClearSelection
Part.SelectByMark "Sketch1", "SKETCH", 0.048006, 0, 0, 1
Part.AndSelectByMark "Sketch2", "SKETCH", 0.04763542, 0, 0, 1
Part.AndSelectByMark "Sketch3", "SKETCH", 0.04718447, 0, 0, 1
Part.AndSelectByMark "Sketch4", "SKETCH", 0.04657279, 0, 0, 1
Part.AndSelectByMark "Sketch5", "SKETCH", 0.04572, 0, 0, 1
Part.AndSelectByMark "Sketch6", "SKETCH", 0.04457254, 0, 0, 1
Part.AndSelectByMark "Sketch7", "SKETCH", 0.04318397, 0, 0, 1
Part.AndSelectByMark "Sketch8", "SKETCH", 0.04163467, 0, 0, 1
Part.AndSelectByMark "Sketch9", "SKETCH", 0.040005, 0, 0, 1
Part.InsertProtrusionBlend2 False, False, True
Part.ClearSelection
Part.SelectByMark "Sketch10", "SKETCH", 0.022225, 0, 0, 1
Part.AndSelectByMark "Sketch11", "SKETCH", 0.01805781, 0, 0, 1
Part.FeatureManager.InsertCutBlend 0, 1, 0, 1, 0, 0, 0, 0, 0, 0, 1, 1
If you have any ideas, I'd love some help...
-Adam
