hi everyone...I was making this drawing by ribs and as one surface was round so it is showing this doesn't intersect so cant create rib.I did try by adding a same line on the round face and got the rib but doesn't look good.Any suggestion???.
I have a different version of SW than you so the pictures will have to do.
Try to create the rib at the widest section and use the rib tool to extrude it one direction for the full thickness. I sketched on a plane that was half the thickness from the right plane.
Next I deleted the face (delete and patch) on the highlighted surface.
If you want your rib face to be flat, your outer cylinder will essentially end up with a flat in it or you will have to extend the top face of the circle as you showed in your first image.
