I have a part that was converted to sheetmetal. This process did not create a flat pattern configuration, and thus there is no flat pattern view in the drawing file. Is there a way to fix this?
I do current have a configuration to display the flat pattern set-up. However, it does not display the bend line notes in the view.
Thank you,
Jim Walsh
SW2016 SP3.0
Windows 7
Hi James,
I have had this behaviour frequently. I used to make a config with the flat such as you have but have found another "workaround".
In the main config I change the part to the flat model by selecting the flatten command.
Then I go to the drawing and insert new part, (which shows up flattened), and select the flat pattern which, by magic, is now available. The new view is the proper flat pattern.
Then I go back to the part and deselect the flatten command.
The proper derived config of the flat pattern is now in place and all is right with the world.
Bizarre but works... Thanks for posting your files. It helps a lot!
