I have PC board with few components on it. There are parts on both side of the board (sorry I can't upload the part file) I need to relocate few components to the other side. I found out this PC board was initially saved as a part file. How can I save as an assembly file? Any help is appreciated.
If the Part still exists as separate bodies you can save out the bodies as separate Parts and then re-assemble them into an Assembly. If they aren't then you may need to directly edit the Part file to make the changes.
