4 Replies Latest reply on Oct 10, 2017 8:59 AM by Siavash Khajehhasani
    What is the difference between "static, environnemental and total pressure"?
    Remal Youcef
      Hello;
      What is the difference between "static, environnemental and total pressure" and when we use each of them?
      Thanks.
        • Re: What is the difference between "static, environnemental and total pressure"?
          Matt Peneguy
          I think your terminology is a little different.  But here's a good explanation:
          Pressure measurement - Wikipedia
            Mark Keown
            Click on the help button and you will find joy and happiness.
              Hello Remal,
              Static Pressure:
              In fluid dynamics, static pressure is the pressure at a nominated point in a fluid.
              In Aerodynamics: To distinguish it from the total and dynamic
              pressures, the actual pressure of the fluid, which is associated not with its motion but with its state,
              is often referred to as the static pressure, but where the term pressure alone is used it refers to this
              static pressure.
              Dynamic Pressure:
              In incompressible fluid dynamics dynamic pressure (indicated with q, or Q, and sometimes called
              velocity pressure) is the quantity defined by: q = ½ ρv²
              Total Pressure:
              In fluid dynamics, total pressure (p0) refers to the sum of static pressure p, dynamic pressure q,
              and gravitational head, as expressed by Bernoulli's principle:
              p0 p = q + ρgz
              The total pressure is also called stagnation pressure.
              The basic impact tube consists of a tube pointing directly into the fluid flow. As this tube contains
              fluid, a pressure can be measured; the moving fluid is brought to rest (stagnates) as there is no
              outlet to allow flow to continue. This pressure is the stagnation pressure of the fluid, also known as
              the total pressure or (particularly in aviation) the Pitot pressure.
              Environment Pressure:
              Unlike static, dynamic and total pressures, the Environment Pressure is not a physical quantity. It is
              merely a type of boundary condition in Flow Simulation. The Environment Pressure condition is
              interpreted by Flow Simulation as a total pressure for inlet flows and as a static pressure for outlet
              flows. If in the course of calculation a vortex crosses an opening with the Environment pressure
              condition specified, this pressure is considered as the total pressure for the part of opening through
              which the flow enters the model and as the static pressure for the part of opening through which the
              flow leaves the model.
              Now the question could be: what if you apply static pressure at outlet of equal magnitude instead of environmental pressure, how different your results are going to be?
              The only difference between static pressure and environmental pressure depends if there is vortex
              flow near the opening. If there is no vortex flow then there should be no difference.
              If there is a vortex near the opening, the flow that is coming back through the opening is calculated
              using static pressure if a static pressure boundary condition is applied at the opening. If
              environmental pressure is used as the boundary condition then the flow is calculated assuming total
              pressure. Environmental pressure is more accurate if there is vortex flow near the opening. If there
              is no vortex flow near the opening then the results should be the same no matter if you use static
              pressure or environmental pressure.
              Regards,
              Siavash
