Batch Check Out
Question asked by Steve Anderson on Oct 4, 2017
Latest reply on Oct 5, 2017 by Steve Anderson
Hello:
I am looking at this specific example in the SolidWorks help files.  The application pertains to API programming for PDM 2017 SP4.1.
http://help.solidworks.com/2017/english/api/epdmapi/Batch_Get_Files_Example_VBNET.htm
At the very end of the example, I have added a few lines of code:
               If (retVal) Then
                   batchGetter.GetFiles(Me.Handle.ToInt32(), Nothing)
end of example above
lines added below
               ' We need a delay
               For c As Integer = 1 To 10
                   MessageBox.Show(c.ToString)
               Next
               Dim enumVarObj2 As IEdmEnumeratorVariable8 = aFile.GetEnumeratorVariable
               SetReviewer(enumVarObj2, 1)
               MessageBox.Show("Done...")
The gist of things is that the example above does a batch check out.  The next step is to transition to updating some values on the card below.  If I check the file out manually, the card update logic works great.  However, it seems there must be some kind of refresh required because when I try to combine the functionality it thinks the file is still checked in and thus will not update the card.  I added the delay, and I wait until it is confirmed checked out, however the logic still fails.
Let me know if you have any thoughts.
Steve Anderson
