Macro Batch export multisheet solidworks to multiple dwg with modelname as dwg filename
Question asked by Nicolas Box-Rubio on Oct 5, 2017
Latest reply on Oct 5, 2017 by Amen Allah Jlili
Hi guys,
I need to improve a macro I'm actually using to export each sheets of a Solidworks drawing into separate dwg file using the model's filename shown on the sheet as the filename of the dwg.
Example:
Sheet1: model 46407-C    -> dwg file: 46407-C.dwg
Sheet2: model 46407-C1  -> dwg file: 46407-C1.dwg
Sheet3: model 46407-C2  -> dwg file: 46407-C2.dwg
So far I'm using the following macro to save, export as a single pdf, exports to separate dwg and close the drawing but it exports the sheets to dwg files named 00_46407-C.dwg
Set Part = swApp.ActiveDoc
On Error Resume Next
Dim FilePath As String
Dim PathSize As Long
Dim PathNoExtension As String
Dim NewFilePath As String
FilePath = Part.GetPathName
PathSize = Strings.Len(FilePath)
PathNoExtension = Strings.Left(FilePath, PathSize - 6)
NewFilePath = PathNoExtension & "slddrw"
Part.SaveAs2 NewFilePath, 0, True, False
'MsgBox "Saved " & NewFilePath
NewFilePath = PathNoExtension & "pdf"
NewFilePath = PathNoExtension & "dwg"
swApp.ActiveDoc.ActiveView.FrameState = 1
Set Part = Nothing
swApp.CloseDoc FilePath
swApp.ActiveDoc.ActiveView.FrameLeft = 0
swApp.ActiveDoc.ActiveView.FrameTop = 0
\'Set Part = swApp.ActiveDoc
'Set SelMgr = Part.SelectionManager
'swApp.ActiveDoc.ActiveView.FrameState = 1
'Part.Extension.SaveAs "M:\OEM projects\2008\Q059638 Boeing 10-60593-16 Return Filter Assembly\RECENT PDF'S\1761291-01.PDF", 0, 0, Nothing, longstatus, longwarnings
Thanks for your help.
Nicolas
