Hello all,
I am having an issue when I draw a wire between multiple connection points in a line SWE will only connect the two end points and ignore all of the intermediate points.
The only way I can get the points to connect is if I purposely draw separate segments out of line.
Hi Stephen,
Do you have a picture of the setup that you're trying to draw a wire across? Perhaps one of where you're starting from then another of what you're wanting to achieve?
