Macro 3D PDF
Question asked by Samuel Savage on Oct 5, 2017
Latest reply on Oct 5, 2017 by Jacob Corder
Hi Everyone,
Wanted to see if anyone out there could help me out, I'm trying to set up a Marco for converting an Assembly into a 3D PDF, I've taken code from here How to create 3d pdf automatically?  but have had no luck with getting it to work. I have a PDF macro for drawings (code below) that was created before my time that I was basing the 3D PDF but my knowledge of coding is limited and wanted to know if anyone has come across any examples of how to set this up.
Thanks in advance,
Samuel
Option Explicit
    Dim swApp                   As SldWorks.SldWorks
    Dim swModel                 As SldWorks.ModelDoc2
    Dim sPathName               As String
    Dim sRev                    As String
    Dim nRetval                 As Long
    Dim bShowMap                As Boolean
    Dim swModelDocExt           As SldWorks.ModelDocExtension
    Dim swExportData            As SldWorks.ExportPdfData
    Dim boolstatus              As Boolean
    Dim swCustProp              As CustomPropertyManager
    Dim valOut                  As String
    Dim resolvedValOut          As String
    Dim swView                  As SldWorks.View
    Const sPath                 As String = "\\server-02\company documents\Claydon Yieldometer.Ltd\Manufacture\Design Technical Drawings\All Drawings" ' Change path here
    Set swModel = swApp.ActiveDoc
    sPathName = Mid(swModel.GetPathName, InStrRev(swModel.GetPathName, "\") + 1)
    sPathName = Left(sPathName, InStrRev(sPathName, ".") - 1)
If (swModel.GetType = SwConst.swDocumentTypes_e.swDocDRAWING) Then
        Set swView = swModel.GetFirstView
        Set swView = swView.GetNextView
        Set swCustProp = swView.ReferencedDocument.Extension.CustomPropertyManager("")
        swCustProp.Get2 "Revision", valOut, resolvedValOut
        Set swExportData = swApp.GetExportFileData(swExportPDFData)
        boolstatus = swExportData.SetSheets(swExportData_ExportAllSheets, 1)
        boolstatus = swModel.SaveAs4(sPath + "\" + sPathName + "-" + resolvedValOut + ".PDF", swSaveAsCurrentVersion, swSaveAsOptions_Silent, 0, 0)
        swApp.SetUserPreferenceToggle swDXFDontShowMap, False
        If boolstatus Then
            MsgBox "EXPORT OF " & sPathName + " SUCCESSFUL" & vbNewLine + "PDF SAVED TO ALL DRAWINGS"
        Else
            MsgBox "Save as PDF failed." & vbNewLine + "Ensure PDF isn't already open"
