So I'm stuck with a problem I can't solve. I'm trying to cut a 45 degree (basically a miter) into this face with the linear holes punched down it. The end goal is to have the face with the holes at 90 degrees from the static side that doesn't get bent. My game plan was to miter the bend on the far left of the drawing below
So far so good. From here I unfolded the part and created a cut extrude
Refold it....
And not its off the right angle it was before...
I can't wrap my head around whats happening here. Any help would be much appreciated!
Sean,
You can use the Measure tool to check the faces and they are at 90°
If you measure edges like that within a sketch you are likely to get yourself in all sorts of trouble.
