5 Replies Latest reply on Oct 3, 2017 8:27 PM by Vladimir Urazhdin
    Best method for working with configurations in drawings
    Dom Enico
      Hi All,
      I have designed a simple table model for a table which consists of two configurations.
      I want it to be as simple as possible to create drawings and cut-lists so I'm using DriveWorksXpress to generate these.
      The 'master' drawing I have made changes based on the configuration selected in the model through the DriveWorksXpress input. However, this leaves me having to edit drawings because of the references that are lost with the configuration change.
      Instead, I'm thinking of having the different configurations on separate sheets. From here, is there a simple way to delete the sheets if a certain configuration is selected?
      Eg, Sheet 1 belongs to Config A and Sheet 2 belongs to Config B. I select Config B in the model and Sheet 1 gets deleted from the drawing file.
      Alternatively, is there another way to do this altogether?
      Thank you.
