MBMatt B.03/10/2017
So I have written a macro that succesfully creates a MidPlane sheetmetal base flange - it creates an offset plane, moves a sketch to that plane, creates a sheetmetal flange, and then adds equations to make the plane offset be the half-width of the sheetmetal.
My problem is that my code currently makes all of the sheet metal features use the newly selected thickness, instead of just the new feature. (I.E. I want this new flange to be it's own thickness from a table, selectable by user. But this new selection gets applied globally, instead of just locally)
Also, critically, SolidWorks doesn't create a "D7@Sheet-Metal#" custom thickness dimension to use in the above equations.
Does anybody have any idea why these two things happen? Here's the operative code:
Dim featDef As SldWorks.BaseFlangeFeatureData
Set featDef = swFeatmgr.CreateDefinition(swFmBaseFlange)
' need to ask user for thickness preference
nStatus = swSMFeatData.GetUseGaugeTable(bRet, sTableFile)
featDef.BendRadius = swSMFeatData.BendRadius
featDef.D1OffsetDistance = 0#
featDef.D1OffsetType = 0
featDef.D1ReverseOffset = False
featDef.D2OffsetDistance = 0#
featDef.D2OffsetType = 0
featDef.D2ReverseOffset = False
featDef.OffsetDirections = 0
featDef.ReverseDirection = False ' This line seems to control closed-profile base flange thickness direction.
featDef.ReverseThickness = False
'All of the following values depend on the previous values;
' you must set these values in sequence
featDef.UseGaugeTable = True
' Set the path to the sheet metal gauge tables
featDef.GaugeTablePath = sTableFile
ThicknessNames = featDef.GetTableThicknesses()
If (IsEmpty(ThicknessNames)) Then
    MsgBox "ERROR: No sheetmetal table. At this time,this sheet metal body cannot be the first one in the model."
    'TODO: Load thickness table seperately, use userform input to create sheetmetal
    End
Else
    gThicknessNames = ThicknessNames
   ' get user input
    UserForm1.Show
' Set override values
If gUseDefault Then
    override = False
Else
    override = True
If (override = True) Then
    featDef.OverrideRadius = False
    featDef.OverrideThickness = True 'False ' hoping this lets the system choose table radius and kfactor
    featDef.OverrideKFactor = False
    featDef.ThicknessTableName = gUserThickness
Else
    featDef.OverrideThickness = False
Set swNewFeat = swFeatmgr.CreateFeature(featDef)
