6 Replies Latest reply on Oct 4, 2017 5:12 AM by Marco Maso
    EqualSegment always returns false
    Marco Maso
      I'm trying to use the EqualSegment method on some splines but it always returns false.
      I'm in the AfterClose() of a PropertyManager. I can retrieve the sketch, enter inside it, recover all sketch segments but, foreach sketch segment, EqualSegment fails.
      Varying the number of points doesn't change the outcome. Of course the API only returns a generic 'false'..
      Do you have any clue on this? Thanks in advance.
        • Re: EqualSegment always returns false
          Manikandan Babu
          Hi Marco,
          I have worked out the example it is working fine in SolidWorks 2017.
          Can you provide the sample set of files to check your workflow.
          Manikandan
              Marco Maso
              Hi Manikandan, thanks for the reply.
              I extracted the relevant code.
              public void SplineSmoothingClicked()
                  // <retrieving Solidworks components (e.g. swSelectionManager)>
                  List<Feature> features = new List<Feature>();
                  for (int i = 1; i <= swSelectionManager.GetSelectedObjectCount2(-1); i++)
                      if (swSelectionManager.GetSelectedObjectType3(i, -1) == (int)swSelectType_e.swSelSKETCHES)
                          features.Add((Feature)swSelectionManager.GetSelectedObject6(i, -1));
                  foreach (Feature feat in features)
                      swModel.ClearSelection2(true);
                      feat.Select2(false, 1);
                      swModel.InsertSketch2(false);
                      Sketch activeSketch = (Sketch)swModel.GetActiveSketch2();
                      // <retrieving sketch segments with activeSketch.GetSketchSegments() and casting them to an array>
                      foreach (SketchSegment skSeg in sketchSegments)
                          skSeg.EqualSegment((int)swSketchSegmentType_e.swSketchSegmentType_sketchpoints, 50);
                      swModel.InsertSketch2(true);
              Thanks.
                  Jacob Corder
                  you never instantiated SketchSegments
                  Dim SketchSegments as object
                  SketchSegments = ActiveSketch.GetSketchSegments
                  or simply replace
                  Foreach (SketchSegment SkSeg in ActiveSketch.GetSketchSegments)
                      Marco Maso
                      Hi Jacob, thanks for the answer. Sorry, I wasn't clear enough. I actually retrieve the SketchSegments but I omitted the code (replaced with a '// <retrieving sketch segments with activeSketch.GetSketchSegments() and casting them to an array>') for simplicity sake. Sorry about that. I'm sure I'm targeting the exact segments because GetName() retrieves the effective names but EqualSegment still doesn't work.
                      Manikandan Babu
                      Hi Marco,
                      I think failed to select the sketch segment before EqualSegment in your code.
                      Try this code with part which has sketch1 holds some splines.
                         SldWorks SwApp = (SldWorks)System.Runtime.InteropServices.Marshal.GetActiveObject("sldworks.Application");
                                  ModelDoc2 SwModel = (ModelDoc2)SwApp.ActiveDoc;
                                  PartDoc SwPart = (PartDoc)SwModel;
                                  Feature SwFeat = SwPart.FeatureByName("Sketch1");
                                  SwFeat.Select2(true, 0);
                                  SwModel.SketchManager.InsertSketch(true);
                                  Sketch Swsketch= (Sketch)SwModel.GetActiveSketch2();
                                  SwModel.ClearSelection2(true);
                                  foreach (SketchSegment Sketchseg in Swsketch.GetSketchSegments())
                                      SelectData Seldata=null;
                                      Sketchseg.Select4(false, Seldata);
                                      Sketchseg.EqualSegment((int)swSketchSegmentType_e.swSketchSegmentType_sketchpoints, 50);
                                  SwModel.InsertSketch2(true);
                      Manikandan
