I know you shouldn't sketch unless it's a flat surface(at least that what I've been taught yet)
so my required shape should look like this
and the only remaining part is the last small circle in above.(6 diameter)
Use the hole wizard and pick the circular face. To locate the point that locates the hole, make the point coincident to reference geometry like planes, or temporary axis. You can also dimension the point off of planar faces as well in this case.
SOLIDWORKS - Using Hole Wizard on Nonplanar Surfaces - YouTube
Hi Daniel,
You can draw a sketch on the plane that runs thru the center of the part perpendicular to your intended hole (I'm assuming one of your standard planes is there) then cut extrude from there.
