I have a box with two holes drilled in it from two different sides (90 degrees from each other) that intersect each other. Is there a way i can dimension the second hole so that it alawys intersects the first hole. I want them to stay aligned as i change the distance the first hole is from the edge.
One way to do this is to create a reference parent sketch.
1. You can make generic extrusions with link to the ref sketch...
Another is:
2. You should be able to make a design table. Linked to the dimensions in the parent sketch.
