OK, let me explain:
I create my front view and then select the view and the little pop up appears and the 3rd selection is Projected view:
When I select "Projected View" I can create a projected view (duh!)
However, sometimes, after I create my first projected view, the command will still be on and I can create a second projected view, and then a third.
BUT, sometimes, after creating the first projected view the command will shut off and I will have to re-select it.
What I am asking is this:
What is the criteria behind why the projected view command will continue to be active after the first projected view is created and what is the criteria behind why it shuts off sometimes after the first view is created?
There must be a reason, I am just not seeing the pattern.
If I haven't explained this well enough, please let me know.
