How does one delete extension lines when dimensioning in a drawing?
The solid lines projected from the dimension are crossing into my model and appearing as intersecting lines.
I realize we are able to change these to dashed lines and also drag and reposition the extension lines however either of these options are not prefered.
Please help!
Nolan
You can hide them. Right an extension line and select 'Hide'. You can also 'Break' them in the property manager for the dimension, which will put breaks in the extensions lines where they cross others.
However, the best solution is usually to find a better way to dimension it. Can you post an image of the area where you are having problems?
