Hello, i am creating Y duct piece. It have cut on it, but after opening it flat both cut have different shape.
as you can see in above image, cut on both side have different shape.If you do unfold command its show both cut shape same.
I have designed same type parts with different dimensions, they didn't had this problem.
I have also attached model file. If there is problem with modelling , please tell me.
Hi Manindra, Hi Dennis, Hi John,
I had a look at the model and I tend to agree that the behaviour of this sheet metal part is something to report to our Support Team. I can't see a reason why a symmetrical folded part turns out with an asymmetric flat pattern.
But I would like to add a few comments:
Old parts have several independent sheet metal definitions and several flat patterns in the tree:
Whereas new architecture parts have a common sheet metal definition nodes and flat pattern nodes in the tree:
Way back before there was base flange or lofted bend you would have to create your sheet metal tubes or cones like this.
I have attached my part in 2016 format in order to comprehend my steps.
Kind regards
Frank
SOLIDWORKS Product Definition Team
