I'm using Solidworks to design parts to be 3d-printed.
I've noticed that if I'm making an assembly, where one part has features that touch other parts, then when I try to save that assembly as an STL for printing, I'll get a dialog from Solidworks saying "This assembly has coincident or interfering geometry that may be unsuitable for some rapid prototyping systems." If I save it, then this STL later causes problems when trying to print it.
What can I do? I'd like to be able to print my assemblies.
Here is a very simple example assembly where you can see this phenomenon. Part 1 is just a simple cube, and part 2 is another simple cube that is flush with part 1.
Hi Ram,
Do you need the parts to be separate bodies? Or are you after one solid 3d printed part? If you want things to move you need to design in clearances. If you want a solid part, try saving assemblies as part files first. Combine the bodies, then save out as STL.
