Hi all, I am unable to open different Solidworks 3D model configurations in Composer. Can you please look into this issue? Many thanks,
Be aware, there was a bug in SW 2017 Sp2 where configurations didn't show in the dialogue that Dirk Rautenberg shows. this was fixed in Sp3 so ensure you are on this at the very least.
Dirk is absolutely correct! In case this isnt an option check out this work around
Importing different configurations when opening a SolidWorks file
Hi IT Support,
I look into your issue but there are more questions than answers.
You want to open any configuration of a SolidWorks assembly in composer.
1. You has to start composer
2. File > Open
and than select the assembly
3. open the SolidWorks button
You will now find all possible configurations. Select one and open the File.
The composer now use SolidWorks as a background process to convert this config in to smg.
Is this want you want to do?
