A lot has been said about the lineair pattern setting as being faster. So I was looking at a way to have it set as default. So far I can see that when it is set, this will last for the SW session. Restarting will uncheck the box again. Opening a part with a lineair pattern using this feature won't help, so it is not stored in the document.
Going through the registry I found the [HKEY_CURRENT_USER\Software\SolidWorks\SOLIDWORKS 2016\User Interface\Dialogs] with the uiLPatternDlg_c key. I tried to manipulate the settings with no succes.
Anyone tried this and found the setting in the registry?
regards, Marco
