Why does the property Summary Information open when I run a macro with #TASK?
Question asked by Elisabeth Daley on Sep 28, 2017
Latest reply on Sep 29, 2017 by Deepak Gupta
I'm trying to write a simple macro to copy custom properties, and run it using the #TASK application that Deepak Gupta suggested on this thread.  The library macros work great, but when I run the custom one I added, it opens the part and then opens the Properties window, waits until I close it, and then finishes.  How do I keep it from opening the window?  I've tried commenting out literally all of my code, and it still happens.
For what it's worth, here's what I'm trying to run:
' Copy Properties from Workgroup files so PDM datacards work
    ' Array contains mapping from Workgroup properties to coresponding PDM properties:
    Dim workgroupProps
    Dim PDMprops
    workgroupProps = Array("PartNo", "Description", "ProjectEng", "Author", "DrawnDate", "Description2", "NextAssy", "Project")
    PDMprops = Array("Part Number", "Part Name/Description", "Project Engineer", "Designer", "Date", "NextAssyName", "NextAssyName", "Program")
    Set swModel = swApp.ActiveDoc
    Set swCustPropMgr = swModel.Extension.CustomPropertyManager("")
    Dim prop As Variant
    Dim textexp As String
    Dim evalval As String
    Dim i As Integer
    i = 0
    For Each prop In workgroupProps
        swCustPropMgr.Get2 prop, textexp, evalval
        'Debug.Print prop & ": " & evalval
        ' if property has value
        If evalval <> "" Then
        ' create corresponding PDM property and assign value
            swModel.AddCustomInfo2 PDMprops(i), swCustomInfoText, evalval
        i = i + 1
    Next prop
