Wrap command is producing error message. How to fix this?
Your wrap profile is extending beyond the part, shorten it up and it will work just fine:
Even though sketch is extended beyond part, feature is coming, but edge of the cylinder is coincident with end points of the half circle.
Are you going to need something like this? Then you can offset the surface of the rod, extend, wrap by scribe, offset the enclosed scribe area, thicken and combine.
This is different intention with usage of many tools I am going to try this as well for practice.
