Is it possible to put in a weld bead between edge flanges such as in the attached image? I know you can weld corners, but I need to have these flanges welded together.
Thanks, I tried doing this but didn't think it was possible as it didn't create a weld bead for me. It looks like you're doing the same thing successfully though.. :-/
The bead is probably there Ray, you just can't see it. Edit:.. Go ahead and accept that, then go to Hid/Show.
