Hi All,
I'm currently working on a door lock development.
The lock is primarily driven driven by a motor and gears which in turn rotate a shaft both clockwise and anticlockwise.
However the design I'm working on also requires a manual override function (which is independent to the gears).
I've looked, but can't find a sutable mecnism that will enable this functionality, and wondered if anyone had any thoughts or could offer any advice?
Attached is a picture of something close, but this only locks in a anticlockwise direction.... in my design i the lock to engage in both!
so.....When the outer green ring is turned by the motor in either direction i need it to engage the with the blue shaft and turn both.
but
when the blue shaft is turned manualy in either direction i need it to move freely without causing the green outer ring to rotate!
i hope this explains?
As mentioned any thoughts would be great?
regards
Laurence
Did you search for "Sprag Bearings" ?
