Traverse Assembly and Run Different Macros on Different Components
Question asked by Vince Pappert on Sep 26, 2017
Latest reply on Sep 28, 2017 by Jacob Corder
Hey All,
First and foremost, I'd like to thank the users of the API forum for making some pretty awesome macros available for all to use.
I started out only a couple of weeks ago and have learned so much from browsing these forums and just playing around to see what functions do what.
I've written a couple of part property macros with different fragments of code pulled from this site and some personal touches that work well for what they are.
But, I'd like to implement them on a larger scale and I think I'm close, but I'm having some trouble finishing it properly.
Task: Update file properties for all assemblies and parts (1,000+)
Then update drawing templates and sheet formats, rebuild, save, and save to pdf. (I have only touched on this and have failed thus far, not part of today's concern)
Application: Traverse the main project assembly, open assemblies and parts individually, run 1 of 5 macros depending on certain file properties or don't run anything if it is hardware, save part or assembly, close, open next, and so on.
Problems: I have yet to be able to skip over hardware that I do not want to run a macro on.
I am trying to compare the filename to a list, "Screw*", "Washer*", etc. but I get a mismatch error.
Also, I am only able to open parts and not assemblies.
Thank you all in advance for any support and advice you may provide!!
Current iteration:
' Description:
' Traverses the open assembly, activates all components, and runs the proper macro.
Private Const BIF_RETURNONLYFSDIRS As Long = &H1
Private Const BIF_DONTGOBELOWDOMAIN As Long = &H2
Private Const BIF_RETURNFSANCESTORS As Long = &H8
Private Const BIF_BROWSEFORCOMPUTER As Long = &H1000
Private Const BIF_BROWSEFORPRINTER As Long = &H2000
Private Const BIF_BROWSEINCLUDEFILES As Long = &H4000
Private Const MAX_PATH As Long = 260
Sub ShowAllOpenFiles()
Dim swDoc As SldWorks.ModelDoc2
Dim swAllDocs As EnumDocuments2
Dim FirstDoc As SldWorks.ModelDoc2
Dim dummy As Boolean
Dim NumDocsReturned As Long
Dim DocCount As Long
Dim i As Long
Dim sMsg As String
Dim bDocWasVisible As Boolean
Dim OpenWarnings As Long
Dim OpenErrors As Long
Dim DwgPath As String
Dim myDwgDoc As SldWorks.ModelDoc2
Dim drwPathName As String
Dim lErrors As Long
Dim lWarnings As Long
Dim boolstatus As Boolean
Set swAllDocs = swApp.EnumDocuments2
Set FirstDoc = swApp.ActiveDoc
DocCount = 0
swAllDocs.Reset
swAllDocs.Next 1, swDoc, NumDocsReturned
While NumDocsReturned <> 0
    bDocWasVisible = swDoc.Visible
'NEED TO OPEN ASSEMBLIES AND PARTS
    DwgPath = swDoc.GetPathName
       Set myDwgDoc = swApp.OpenDoc6(DwgPath, swDocPART, swOpenDocOptions_Silent, "", OpenErrors, OpenWarnings)
        If Not myDwgDoc Is Nothing Then
            swApp.ActivateDoc myDwgDoc.GetPathName
Dim Part As ModelDoc2
Set Part = swApp.ActiveDoc()
Dim FileName As Variant
Dim retval As Variant
Dim PartNumber As String
Dim Manufacturer As String
Dim valout As String
Dim swCustProp As SldWorks.CustomPropertyManager
Set swCustProp = Part.Extension.CustomPropertyManager("")
        retval = swCustProp.Get4("PART NUMBER", False, PartNumber, valout)
        retval = swCustProp.Get4("MANUFACTURER", False, Manufacturer, valout)
        FileName = Mid(Part.GetPathName, InStrRev(Part.GetPathName, "\") + 1)
        FileName = Left(FileName, InStrRev(FileName, ".") - 1)
'PROBLEM AREA
        If FileName Like "*Screw*" Or "*Washer*" Or "*Nut*" Or "*Dowel*" Then
        MsgBox ("No Hardware!")
        Else
        If Part.GetType = swDocPART And Manufacturer = "MACHINED" Then
            swApp.RunMacro2 "Y:\MACROS\ELITE G3\Solidwork 2016 SP 1.0\MACHINED_EG3_SW16 SP1.0.swp", "MACHINED_EG31", "Main", swRunMacroDefault, Empty
            Else
        If Part.GetType = swDocPART And Not (PartNumber Like "B-*" Or PartNumber Like "D-*") And Manufacturer <> "MACHINED" Then
            swApp.RunMacro2 "Y:\MACROS\ELITE G3\Solidwork 2016 SP 1.0\PURCHASED_EG3_SW16 SP1.0.swp", "PURCHASED_EG31", "Main", swRunMacroDefault, Empty
            Else
        If Part.GetType = swDocASSEMBLY And Not (PartNumber Like "B-*" Or PartNumber Like "D-*") And Manufacturer <> "MACHINED" Then
            Else
        If Part.GetType = swDocASSEMBLY And PartNumber Like "B-*" Or PartNumber Like "D-*" And Manufacturer <> "ASSEMBLY" Then
            swApp.RunMacro2 "Y:\MACROS\ELITE G3\Solidwork 2016 SP 1.0\MODIFIED PURCHASED_EG3_SW16 SP1.0.swp", "MODIFIED_PURCHASED_EG31", "Main", swRunMacroDefault, Empty
            Else
        If Part.GetType = swDocASSEMBLY And PartNumber Like "B-*" Or PartNumber Like "D-*" And Manufacturer = "ASSEMBLY" Then
            swApp.RunMacro2 "Y:\MACROS\ELITE G3\Solidwork 2016 SP 1.0\ASSEMBLY_EG3_SW16 SP1.0.swp", "ASSEMBLY_EG31", "Main", swRunMacroDefault, Empty
    swApp.QuitDoc (Part.GetTitle)
            Set myDwgDoc = Nothing
    DocCount = DocCount + 1
Wend
swApp.ActivateDoc FirstDoc.GetPathName
