Has anyone got the comments to work when you check in a file
using Dispatch? I have entered a comment in Dispatch, but nothing
shows up in the history.
Also, is there a way to move a file using Dispatch and retain the history? I tried using Shell Execute>>>Command Line>>>move but it just created a new copy.
Finally, I can't seem to pull values from the selected file's datacard. I've set up variables that link to the datacard variable, but they remain empty. Any ideas?
Adam
Adam
Regarding the comments during check-in, the help file states: " The action checks in a file only if the current user has the file checked out. If the user made changes, a new version is created using the specified comment. If the user did not make changes, the check out is cancelled."
So in order for comments to be saved the file has to have been changed.
Finally, I don't think it is possible to move a file and keep the history using Dispatch.
Adam
can you give me from the step 1 to last
