Problem with wireframe model display (SW 2015 & 2017)
Question asked by Jedrzej Kurkiewicz on Sep 25, 2017
Latest reply on Sep 26, 2017 by Amen Allah Jlili
Hello All;
I have used a macro to apply the same color as part to wireframe (SW 2015 & 2017).
The macro worked correctly up to a couple of days ago.
I use below code to change the setting in a document options and right after using the macro the model display is ok, but when I reopen the part it loose "colored" wireframe appearance.
Macro code (copied from this thread):
Dim swApp As Object
    Dim bstatus As Boolean
    Set swModel = swApp.ActiveDoc
    bstatus = swModel.Extension.SetUserPreferenceToggle( _
        swUserPreferenceToggle_e.swColorsWireframeHLRShadedSame, _
        swUserPreferenceOption_e.swDetailingNoOptionSpecified, True)
When I do the same task manually, it works fine.
Can someone check if the problem also occurs on Your installation of SolidWorks or maybe anyone has an idea where could lies the problem?
