hi,
why cant i to change a tag letter of table annotation in 2017 version?
for example, in 2015 it works!
follow a picture that show what i am trying to do.
i need change the letters in the first column, but not lose the link with drawing. i want define a specif letter by some holes.
As I understand it, SWX works in defined progression from the bottom left hand corner of the chosen part face containing the holes based upon which holes it reaches first along the X-axis to determine which holes are A', B's, etc.
The best that I've ever come up with is to sequence the holes the way that I want (certain holes be A1, A2, etc., then other certain holes as B1, B2, etc.). You can do this by starting the hole table, choosing the origin, then selecting those holes (not the face) that you want to be A1, A2, etc., place the hole table then edit the hole table from the sidebar and add the next series of holes. You have to expand then recombine the "same size" holes to clean up the table. Time consuming but it works.
